Právě je úte lis 26, 2024 3:03 pm
PříspěvekNapsal: pon dub 07, 2008 3:59 pm
Čo tak skúsiť CELstart?
PříspěvekNapsal: pon dub 07, 2008 5:17 pm
A čo očakávaš, že to spraví?
PříspěvekNapsal: stř dub 09, 2008 4:12 pm
ja tomu tiez nerozumiem, kdekolvek to dam (do hocijakeho adresara) tak napise "...instead place them in the 'adresar, kde subory su'"...instead znamena namiesto, na ich webe som nenasiel navod, co s nimi robit, vsade je len, ze s nimi netreba robit nic, ziadna instalacia, iba rozbalit, a to prave nejde :(
PříspěvekNapsal: sob dub 19, 2008 12:52 pm
Lidi vi stahujete spatne veci http://b2cs.delcorp.org/index.php/ArtistInstall
PříspěvekNapsal: sob dub 19, 2008 7:18 pm
no zatial som pochopil vsetko a aj to vykonal, len teraz nerozumiem tomuto:
Finally, for cs and cel you have to extract the zipfile somewhere and then set the CRYSTAL and CEL variables to point to the included cs and cel directories.
In Windows XP, to set the environment variables right click My Computer, select Properties, go to the Advanced tab and select the Environment Variables button
In Windows Vista, environment variables can be accessed by going to "Control Panel", then click "Classic View", then open "System", then go to "Advanced System Settings" which pops open a "System Properties" dialog with the "Advanced" tab selected, then click "Environment Variables" button.
Here set CRYSTAL variable to the directory path where you have crystalspace (the cs folder in the pycelstart zipfile), and CEL to the directory path where cel is located (the cel folder in pycelstart zipfile). If you dont want to use cel related stuff you dont need to set the CEL variable.
mohol by mi to niekto vysvetlit prosim...? 8)
PříspěvekNapsal: ned dub 20, 2008 11:18 am
mas dat tento pocitac a tam advancet pak Environment Variables a tam new
do valiable name das CRYSTAL a do valiable value adresu ke kodum krystalu
a pak zase akorat tam napises CEL a das tam cestuk celu (me to zas nejde exportovat)
PříspěvekNapsal: ned dub 20, 2008 12:11 pm
a jinak jestli si presto co mate stazene chcete neco zahrad tak si stahnete nejake demo z http://www.crystalspace3d.org/main/CELstart a skopirujte ho do adresare directory
PříspěvekNapsal: sob dub 26, 2008 7:51 pm
zdravim
mam s tim takovy maly problenek:
nefunguje mi to s pythonem 2.5 a ja bych potreboval vedet jek to mam sprovoznit. python 24 nechci protoze by mi pak nefungovala vetsina ostatnich veci zavyslych na 25. dik
PříspěvekNapsal: stř dub 30, 2008 4:35 pm
co ti to pise presne za chybu?
PříspěvekNapsal: pát kvě 02, 2008 3:26 pm
pise mi to ze nemuze najit "behaviourlayer.python"
vim ze to chce 24 protoze v IDLE sem skousel importovat ty moduly co obstaravaji propojeni mezi cel a pythonem psalo to ze je to skompilovany pro 24
to same i cs
chyba.jpg [ 11.98 KiB | Zobrazeno 4440 krát ]
chyba2.jpg [ 91.08 KiB | Zobrazeno 4440 krát ]
PříspěvekNapsal: pát kvě 16, 2008 8:32 am
http://www.crystalspace3d.org/main/Python_Prerequesites#crystalspace.application.celstart:__Can.27t_load_behaviour_layer_.27blpython.27_with_id_.27cel.behaviourlayer.python.27.21
nevim jestli to pomuze ale snad jo
PříspěvekNapsal: pát kvě 16, 2008 5:09 pm
nepomohlo mi to problem neni v tom ze by mi chybely neake soubory problem je v tom ze je zo skompilovane s podporou starsi verze pythonu problem je taky to ze nevim jak to skompilovat a kde sehnat msvc abych to mohl skompilovat teda vim kde sehnat msvc ale je mi to na nic protoze ta instalacka chce neco stahovat s netu a ten ja doma nemam
