Zobrazenà FPS + rozlišenà http://blender3d.cz/forum/viewtopic.php?f=11&t=618 |
Autor: | Jan Železný [ čtv led 06, 2005 8:16 pm ] |
Předmět příspěvku: | Zobrazenà FPS + rozliÅ¡enà |
No uÅ¡ znázvu je jasné že bych chtÄ›l aby moje mikro hra ukazovala poÄ |
Autor: | jm [ pát led 21, 2005 6:57 pm ] |
antialiasing je podle karty a jejiho nastaveni, v blendru neni moc dobrej to je pravda. ani s dobrou kartou to neni nic moc, ale to je obecnej problem. dost pomaha pokud mas ten objekt namapovanej, pak se na to jeste aplikujou veci na reseni textury a vypada to lip, ikdyz je to jen jednobarevna textura. co se tyce FPS tak muzes napsat script, s pomoci pouziti modulu time, nebo sem videl nekde i jinou variantu, a nebo blenderplayer v 2.36 ma moznost ti to ukazet sam. ....show_framerate 1 Kód: C:\Documents and Settings\mucska>"C:\Program Files\Blender Foundation\Blender\bl enderplayer.exe" -h usage: C:\Program Files\Blender Foundation\Blender\blenderplayer.exe [-w [-p l t w h]] -c [-g gamengineoptions] [-s stereomode] filename.blend -h: Prints this command summary -w: display in a window -p: specify window position l = window left coordinate t = window top coordinate w = window width h = window height -f: start game in full screen mode fw = full screen mode pixel width fh = full screen mode pixel height fb = full screen mode bits per pixel ff = full screen mode frequency -s: start player in stereo stereomode: hwpageflip (Quad buffered shutter glasses) syncdoubling (Above Below) sidebyside (Left Right) anaglyph (Red-Blue glasses) vinterlace (Vertical interlace for autostereo display) depending on the type of stereo you want -c: keep console window open -g: game engine options: Name Default Description ---------------------------------------- fixedtime 0 Do the same timestep each frame "Enable all frames" nomipmap 0 Disable mipmaps show_framerate 0 Show the frame rate show_properties 0 Show debug properties show_profile 0 Show profiling information vertexarrays 1 Enable vertex arrays example: C:\Program Files\Blender Foundation\Blender\blenderplayer.exe -p 10 10 320 200 -g noaudio c:\loadtest.blend example: C:\Program Files\Blender Foundation\Blender\blenderplayer.exe -g vertex arrays = 0 c:\loadtest.blend C:\Documents and Settings\mucska> jm |
