Právě je sob lis 23, 2024 6:21 am
 Předmět příspěvku: Zobrazení FPS + rozliÅ¡ení
PříspěvekNapsal: čtv led 06, 2005 8:16 pm
No uÅ¡ znázvu je jasné že bych chtÄ›l aby moje mikro hra ukazovala poÄ
PříspěvekNapsal: pát led 21, 2005 6:57 pm
antialiasing je podle karty a jejiho nastaveni, v blendru neni moc dobrej to je pravda. ani s dobrou kartou to neni nic moc, ale to je obecnej problem. dost pomaha pokud mas ten objekt namapovanej, pak se na to jeste aplikujou veci na reseni textury a vypada to lip, ikdyz je to jen jednobarevna textura.
co se tyce FPS tak muzes napsat script, s pomoci pouziti modulu time, nebo sem videl nekde i jinou variantu, a nebo blenderplayer v 2.36 ma moznost ti to ukazet sam. ....show_framerate 1
Kód:
C:\Documents and Settings\mucska>"C:\Program Files\Blender Foundation\Blender\bl
enderplayer.exe" -h
usage:   C:\Program Files\Blender Foundation\Blender\blenderplayer.exe [-w [-p l
 t w h]] -c [-g gamengineoptions] [-s stereomode] filename.blend
  -h: Prints this command summary
  -w: display in a window
  -p: specify window position
       l = window left coordinate
       t = window top coordinate
       w = window width
       h = window height
  -f: start game in full screen mode
       fw = full screen mode pixel width
       fh = full screen mode pixel height
       fb = full screen mode bits per pixel
       ff = full screen mode frequency
  -s: start player in stereo
       stereomode: hwpageflip       (Quad buffered shutter glasses)
                   syncdoubling     (Above Below)
                   sidebyside       (Left Right)
                   anaglyph         (Red-Blue glasses)
                   vinterlace       (Vertical interlace for autostereo display)
                             depending on the type of stereo you want
  -c: keep console window open
  -g: game engine options:
       Name            Default      Description
       fixedtime          0         Do the same timestep each frame "Enable all
frames"
       nomipmap           0         Disable mipmaps
      show_framerate     0         Show the frame rate
       show_properties    0         Show debug properties
       show_profile       0         Show profiling information
       vertexarrays       1         Enable vertex arrays
example: C:\Program Files\Blender Foundation\Blender\blenderplayer.exe -p 10 10
320 200 -g noaudio c:\loadtest.blend
example: C:\Program Files\Blender Foundation\Blender\blenderplayer.exe -g vertex
arrays = 0 c:\loadtest.blend
