cau
tohle by vas mohlo zajimat, poradil mi ten link Vilda , dik
http://projects.blender.org/viewcvs/vie ... er#dirlist
Kód:
# $Id: KX_SCA_ReplaceMeshActuator.py,v 1.3 2004/09/19 01:33:08 kester Exp $
# Documentation for KX_SCA_ReplaceMeshActuator
from SCA_IActuator import *
class KX_SCA_ReplaceMeshActuator(SCA_IActuator):
Edit Object actuator, in Replace Mesh mode.
Example::
# Level-of-detail
# Switch a game object's mesh based on its depth in the camera view.
# | Always +-----+ Python +-----+ Edit Object (Replace Mesh) LOD.Mesh |
import GameLogic
# List detail meshes here
# Mesh (name, near, far)
# Meshes overlap so that they don't 'pop' when on the edge of the distance.
meshes = ((".Hi", 0.0, -20.0),
(".Med", -15.0, -50.0),
(".Lo", -40.0, -100.0)
co = GameLogic.getCurrentController()
obj = co.getOwner()
act = co.getActuator("LOD." + obj.getName())
cam = GameLogic.getCurrentScene().active_camera
def Depth(pos, plane):
return pos[0]*plane[0] + pos[1]*plane[1] + pos[2]*plane[2] + plane[3]
# Depth is negative and decreasing further from the camera
depth = Depth(obj.position, cam.world_to_camera[2])
newmesh = None
curmesh = None
# Find the lowest detail mesh for depth
for mesh in meshes:
if depth < mesh[1] and depth > mesh[2]:
newmesh = mesh
if "ME" + obj.getName() + mesh[0] == act.getMesh():
curmesh = mesh
if newmesh != None and "ME" + obj.getName() + newmesh[0] != act.getMesh():
# The mesh is a different mesh - switch it.
# Check the current mesh is not a better fit.
if curmesh == None or curmesh[1] < depth or curmesh[2] > depth:
act.setMesh(obj.getName() + newmesh[0])
GameLogic.addActiveActuator(act, True)
@warning: Replace mesh actuators will be ignored if at game start, the
named mesh doesn't exist.
This will generate a warning in the console:
C{ERROR: GameObject I{OBName} ReplaceMeshActuator I{ActuatorName} without object}
def setMesh(name):
Sets the name of the mesh that will replace the current one.
@type name: string
def getMesh():
Returns the name of the mesh that will replace the current one.
Returns None if no mesh has been scheduled to be added.
@rtype: string
