Právě je stř črc 02, 2025 1:02 pm
 Předmět příspěvku: LODa Pydoc
PříspěvekNapsal: ned lis 21, 2004 2:54 pm
cau
tohle by vas mohlo zajimat, poradil mi ten link Vilda , dik
http://projects.blender.org/viewcvs/vie ... er#dirlist
Kód:
# $Id: KX_SCA_ReplaceMeshActuator.py,v 1.3 2004/09/19 01:33:08 kester Exp $
# Documentation for KX_SCA_ReplaceMeshActuator
from SCA_IActuator import *
class KX_SCA_ReplaceMeshActuator(SCA_IActuator):
   Edit Object actuator, in Replace Mesh mode.
   Example::
      # Level-of-detail
      # Switch a game object's mesh based on its depth in the camera view.
      # | Always   +-----+ Python    +-----+ Edit Object (Replace Mesh) LOD.Mesh |
      import GameLogic
      # List detail meshes here
      # Mesh (name, near, far)
      # Meshes overlap so that they don't 'pop' when on the edge of the distance.
      meshes = ((".Hi", 0.0, -20.0),
                (".Med", -15.0, -50.0),
           (".Lo", -40.0, -100.0)
      co = GameLogic.getCurrentController()
      obj = co.getOwner()
      act = co.getActuator("LOD." + obj.getName())
      cam = GameLogic.getCurrentScene().active_camera
      def Depth(pos, plane):
         return pos[0]*plane[0] + pos[1]*plane[1] + pos[2]*plane[2] + plane[3]
      # Depth is negative and decreasing further from the camera
      depth = Depth(obj.position, cam.world_to_camera[2])
      newmesh = None
      curmesh = None
      # Find the lowest detail mesh for depth
      for mesh in meshes:
         if depth < mesh[1] and depth > mesh[2]:
            newmesh = mesh
         if "ME" + obj.getName() + mesh[0] == act.getMesh():
            curmesh = mesh
      if newmesh != None and "ME" + obj.getName() + newmesh[0] != act.getMesh():
         # The mesh is a different mesh - switch it.
         # Check the current mesh is not a better fit.
         if curmesh == None or curmesh[1] < depth or curmesh[2] > depth:
            act.setMesh(obj.getName() + newmesh[0])
            GameLogic.addActiveActuator(act, True)
   @warning: Replace mesh actuators will be ignored if at game start, the
      named mesh doesn't exist.
      This will generate a warning in the console:
      C{ERROR: GameObject I{OBName} ReplaceMeshActuator I{ActuatorName} without object}
   def setMesh(name):
      Sets the name of the mesh that will replace the current one.
      @type name: string
   def getMesh():
      Returns the name of the mesh that will replace the current one.
      Returns None if no mesh has been scheduled to be added.
      @rtype: string
